Image quality.
I am totally fascinated by Andrey Pestryakov's Medieval Lands so much so that I went ahead and purchased it, however I am most disappointed in my resultant image quality (See att) The picture is very flat and without detail and I am unable to zoom into the back-ground.  I am obviously doing something wrong or, I need an additional item or, whatever. The attached image is pre-render using outdoor lighting at 200%, not good I think you'll agree. Even the water does not show with any clarity. It would be helpful if someone could tell me where I've gone wrong with this and perhaps suggest how I might correct it.
Thank you so much.
1303 x 920 - 249K
  • 3WC3WC Posts: 1,172
    What does it look like rendered?
  • FishtalesFishtales Posts: 6,245
    Are you rendering in Iray because it is Iray only by the looks of it?
  • fastbike1fastbike1 Posts: 4,085
    @Cat_Dancing
    A texture shaded Viewport view will never give you an accurate impression of the final iray render. iray's magic is modeling the behavior of light.
