Morph loader pro. negative morph. (solved)
When I create a morph, it allows you to dial it back to -1, distorting the mesh. Is there a way to prevent this, so that the morph's range is only between 0 to 1 instead of -1 to 1?
Edit* I figured it out. It looks like it loads from -100% to 100%, but you can then click on the options wheel, on the actual morph itself (under parameters tab) click on parameters settings and change the min and max values.
Post edited by BradCarsten on
Actually you can set that and alot in morphloader the options menu just has to be shown.
