Daz interface Content Library
for some reason Daz pro beta was put on my computer, my Daz was upgraded with out me knowing, yes it happened, but being that happened when I logged into the program it had some tabs that I have do not use and not the tabs I use, Content Library and a few others I use, only the scene surface eviorment tabs were there, and they were not under that  window/pane tab   I was not able to use it at all, when I called up one of my saved scene files that were all corrupted,  please help! right now I have lost everything I have worked on for a long time.
  • LaandanLaandan Posts: 62
    Ok I fixed it by taking out the one that was used to upgrade my DAZ3d and downloaded a fresh 4.10 pro,   everything I needed and wanted was there, where the corrupted copy of Daz came from I have not clue, so I have my Daz back now
  • Richard HaseltineRichard Haseltine Posts: 111,408
    The Beta may have appeared in your Install Manager list at the same time as a lot of other updates and so ended up being installed in error if you batch-selected - it wouldn't install itself without your instruction.
    The beta and the release versions have different UI settings (among other things), so the layout would be expected to differ. It is possible to syn them, if desired, using the script here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/general_ui/copy_ui_from_channel/start (download and drag it into the Viewport of the version you wish to modify).
