Environment Map
in New Users
Can I not display the Environment Map when rendering? Where is the setting? Thank you!
Hope this helps.
Note that this will only work well when the Environment map is moderately huge (typical sizes 8000 or even 12000 pixels wide). Small map images, such as the default one, is more likely to produce a blurry mess as the background — the whole width of the image is being stretched out in a 360° circle around the camera, not just the tiny slice in the camera's field of view that ends up in the render.
