Continue dForce Sim
Is there a way to continue a dForce sim? After cancellation, I sometimes want dForce to run longer, but it always clears the morph/position and re-starts from scratch.
  • barbultbarbult Posts: 27,681
    No, there is no capability to restart where you left off.
  • TooncesToonces Posts: 919
    Thanks for the response!
    edited April 2019
    Maybe you could export the first simulated shape as a morph, then apply that morph and start simulation again from that morphed shape, but that sounds like a lot of work, and I don't know how well it would work.
    Post edited by barbult on
    Yeh, that would be too time intensive.
    I like to use the animated simulation, because after it finishes, you can select any of the frames of the timeline for your render. Sometimes I prefer something other than the very last frame.
  • nicsttnicstt Posts: 11,715
    edited April 2019
    +1
    Although I avoid animating unless really necessary.
    Post edited by nicstt on
    Let's say I have 5 characters, all individually dForced with 30frame animations. Now I want to merge them together, using frame 10 for char 1, frame 22 for char 2 and so on...is this doable without having to make morphs for every dForced item?
