Saving props question
Is there a way say if I take an item from an environment scene and then add another item to it to save both together as a prop to reuse in future? Like when I make a new pose I can save and use again.
  • Richard HaseltineRichard Haseltine Posts: 111,976
    I'm not quiteb sure what you want, but a Scene Subset may be the answer (assuming this is Daz Studio).
  • beachlegsbeachlegs Posts: 532
    edited April 2019
    Can I ask what that is.......I just wanted to save an item as a prob so I can use again without having to upload a whole environment like a full room when I just need a cup for example. Yes using Daz.
    Edited to fix quote
  • mr clammr clam Posts: 707
    In the "save as" menu, there is an option for saving a figure/prop. You can find it later in "my library"
    edited April 2019
    Thank you my friend just playing with that now I appreciate your help :)
    Edited to fix quote
    Figure/prop is in File>Save As Support Assets and should not used on something that is already saved as an asset. Use File>Save As>Scene Subset, as I suggested above.
  • Silent WinterSilent Winter Posts: 3,970
    ^As Richard said, use 'Save As > Scene Subset'
    I use this a lot for saving fully clothed characters that I want to reuse, or a table full of clutter. In products it's used to load groups of props in one click.
    edited April 2019
    Thank you so much Richard I have some time to go try it out now didnt have much luck last night thanks again :)
    Edited to fix quote
    edited April 2019
    Thank you :)
    Edited to fix quote
