Why does SSS look so weird...?
Upirium
I rarely render on SSS so I'm not quite sure if I'm doing something wrong. I rendered these 3 in SSS and it just looks odd. Am Imissing something? Is there a recommended setting for SSS? TBH I find non-SSS renders seem MORE realistic somehow in some aspects but maybe I'm not rendering right?
using Poser obviously.
993 x 804 - 1M
993 x 804 - 2M
993 x 804 - 1M
what kind of lighting are you using?
That looks like a lighting issue to me. See how much yellow is in the entire scene?
Some SSS renders for comparison.
I'm using like...
um...
idk, it's some kind of light and light helper.
I can't remember wat it's claled but I use like an orb that moves the lgihts.
The yellow was an after effect. I liked the yellowish color for the picture. I added that in Photoshop with Lighting Effects.
However one or two of the lights were colored with a slight yellow tinge.
I felt like it went with the forest lighting in the background.
Yeah, but if you also enhanced the yellow effect in postwork, then you made the yellow that the lights brought to the scene worse. Lighting is very important, and I've learned also that yellow light can really tint a skin and make it look bad.
I don't want to sound like a broken record, but lighting is EXTREMELY important. You might want to learn more about the light you're using. Really no point in using SSS if you're going to use poorly used or heavily tinted lighting. Those things will wash out the quality of the textures.
You might want to try doing an ambient light with at a low setting and then adding some soft spot lights to highlight important areas.
This is why I generally do not use SSS, but I LOVED the way she looked so I got her but she only has SSS options. No regular texture options.
I am aware of lighting, and I am still very, very novice about it despite my three years of Poser...
Understood, but my points were general comments, not specific to SSS. Because of the normal higher quality of the SSS effect, poor lighting is emphasized more. SSS itself is very nice to use.
Are you using I3'd Pro Lights and Helper system? This product is mainly IBL based lighting. If you are using it, uncheck IDL in your render settings. If you are using IDL, you no longer need to use IBL's. If you are doing an outdoor scene with IDL, You really only need Bagginsbill's Environment dome and a single infinite light. Just make sure IDL is checked. If the figure seems to be bouncing too much light, you can try unchecking light emitter in parameters.
I'd note, as a general observation, that it isn't just light that's important. Shadow is to.
As already stated, I tend to avoid yellow tinting unless it is very soft.
Looking at the second image in particular I'd say there's a little too much light in the scene. In photographic terms, it's "over exposed".
