Custom texture not rendering
I've never had this issue before. The texure is a custom for genesis and it won't render. The Model just appears white as though no texture has been applied. I've tried it with default textures and it rendered fine. I've tried renameing the custom texture, that didn't work. The texture is 4096 X 4096. Is this a new glitch for DAZ Studio? Am I the only one who has had this issue?
  • Okay, for whatever weird reason the texture won't work as a Jpg. I had to convert it to a Bmp in order to get it to work.
  • SimonJMSimonJM Posts: 6,113
    If that's under 3Delight, using AoA Shaders then a known issue wheerby some tempotrary files can go missing to be corrupted.  Usual solution is to clear out the DS temp folder of the .tdl files or to cycle DS.
