Lights - Setting Diffuse/Spec options
Doc Acme
I found this last night, I guess by accident, but can't now. There's an option SOMEWHERE (one would think it would be in the Lights panel) to optionally enable a lights Spec & Diffusion attributes.
Where is that found?
Those options are only for 3Delight render lights.
You need to be set for 3DL renders.
Oops, too slow.
one of the features of a biased rendering engine like 3Delight is the ability to customize how lights and surfaces work (e.g. specular only lights or objects that don't cast shadows). SOME of that is possible with Iray (with light paths), but a LOT harder.
However, if you just want to adjust diffuse and specular strengths in post work, you can use Iray canvases to separate the two and layer them together in something like GIMP or Photoshop.
Interesting, or rather strange & curious. Didn't realize I was in 3Delight so makes sense now. New system w/ dual RTX cards so mostly testing things with the GPU's in Iray.
Thanks.
