Objects shrinking in scene!?
MeyghenMeyghen Posts: 18
Hi there, thanks for taking the time to read this.
So basically I've been working on a project, moat, castle and stone walls around it all...
I saved the project last night .. Then returning to it recently, everything was fine but when I tried adding something into the scene.. The objects in the scene shrunk...
I'm sorry I don't have any more to say, I'm just baffled if someone could help that would be amazing, I would hate to have to re do all the scene.
Many thanks!
  • fixmypcmikefixmypcmike Posts: 19,744
    What was the item you added, and were items in the scene parented to it? What application and version are you using?
  • TotteTotte Posts: 15,389
    If you have scaled an object up/down and then parent another object to that object the parented object will inherit scale. It happened to me in the beginning when I had a ground that was 400% and added stuff to it and the stuff added was upscaled 400% making it look like the other items was scaled down.
  • JaderailJaderail Posts: 0
    edited November 2013
    I do believe that can be changed with the Parent in Place setting. I'm sure it is one switch only.
    The setting is at the Bottom of the Right Click Parenting Options menu.
    Post edited by Jaderail on
  • MeyghenMeyghen Posts: 18
    Thankyou all for your responses. :)
