Nancy not loading
At least two of my actors are not working. Primarily, I instaled the Nancy Pro bundle. The actor shows as well as all parts (body, head, etc.) but when I load it, it appears to be the default G8. I can use some changes - materials like lips, make up, nails do load but the head and body shape does not. It shows Nancy at 100% under Actor in Parameters. Loading the Nancy full shape, Nancy body, Nancy head does not change anything. This has not happened to me before. Am I missing a basic thing like loading some morph or checking some box? (The other character not loading is Star 2.0) If I load, say, Serenity, it works correctly. So does Mrs Chow. Any tips? I did not find an answer when I searched the forum.
I am running a Mac Mini under macOS 10.14.3
Daz Studio version 4.10.0.123 Pro Edition (64-bit)
997 x 865 - 596K
  • Richard HaseltineRichard Haseltine Posts: 112,361
    edited March 2019
    That doesn't look like the default Geensis 8 Female to me. Try using Edit>Figure>Zero>Zero Figure Shape - does it then change?
  • I tried with no change. Started a new one (the one above had some coloring) and got nothing. Is this some other figure instead of G8?
    849 x 389 - 114K
  • FSMCDesignsFSMCDesigns Posts: 12,859
    click on genesis 8 female and then go to the parameters tab and at the top will be a section called "currently used" which will list all morphs being used on the figure. From there you should be able to tell if the Nancy morph is active. I know lots of characters that don't look right until you have the addon skin on them also and render it.
  • SolarphageSolarphage Posts: 6
    edited March 2019
    Hm, Nancy and Gen  8, no other list of morphs... Rendering looks the same (not Nancy)
    If I instead load Sakura 8, I get the Sakura 8 morphs (second pic)
    670 x 376 - 36K
    649 x 429 - 61K
    Post edited by Solarphage on
    That is odd, the Nancy character is listed, but none of the morphs appear to be active. Click on the Nancy figure and then expand the nancy section and look at the ACTOR section and expand on that to the FULL BODY - PEOPLE section and scroll thru the morphs till you find Nancy (assuming it is a full body morph) and make it active
    758 x 710 - 286K
  • It has always shown Nancy at 100% but the shape does not look like her. I tried applying other figures and they do apper, except Star 2.0, so far.
