Set multiple hidden parameters/morphs to zero.
Hi, I'm struggling to figure out how to set multiple hidden parameters to zero. I'm using Marvelous Designer to create morphs for clothes for specific figures. In order to do this I need to change all the parameters created by autofitting clothing to zero. I currently have to do this manually every time, which usually means up to 50 parameters being manually set to zero. Is there a better way?
Thanks
363 x 629 - 48K
Post edited by tillwillbill222 on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Edit>Figure>Clear Generated Morphs (with the figure not morphed).
  • Edit>Figure>Clear Generated Morphs (with the figure not morphed).
    Thanks for the response Richard. I may have been a bit confusing with my original post. Is there a "Clear Generated Morphs" option for the clothing itself? I don't want to clear morphs on the figure, just the clothing that is fitted to the figure.
    Unfit clothing and select it, use zero figure shape?
    Sorry, I meant with the clothing selected but the figure not morphed (so it doesn't generate new morphs in the clothing).
