Saving new (combined) morphs
Reality1Reality1 Posts: 115
Is there an easy way to create a single "full body" morph in DAZ Studio once a (Genesis 8) figure is adjusted?
Post edited by Reality1 on
    Simply select your character and save as a shaping preset.
  • Reality1Reality1 Posts: 115
    edited March 2019
    Hmmm. It looks like that may just save the individual morph settings.
    There used to be a way to save a new morph target so the system didn't have to use all of the individual morph resources. Is still an option without buying a utility?
    edited March 2019
    With the morhs dialed in, zero the figure pose, set resolution to base and export as .obj. Load a new G8 base character and use morphloader to import the morph. That will create a single morph slider. You will probably have to check the auto-follow box in slider settings.
    Post edited by Sven Dullah on
  • Cris PalominoCris Palomino Posts: 12,959
    edited March 2019
    Are you creating this by dialing up different morphs and want to have a new dial to dial the morphs up at the same time? Is it only dials?
    This post may have information you want. https://www.daz3d.com/forums/discussion/comment/4440306/#Comment_4440306
    Post edited by Cris Palomino on
