modo to daz, daz to modo...import/export help?
jardinejardine Posts: 1,227
edited March 2019 in The Commons
if you're familiar with these workflows (or either of these workflows) what settings work for you?  what do i need to keep in mind?
i'm finally modelling a little, and i'm having a hilariously hard time dealing with scaling and surfaces/surface groups.  and, for some reason, getting an object modelled in a zeroed position and location in modo to appear at a zeroed location in studio after import.
also--i've been exporting obj objects from modo, and exporting/importing obj objects from/to studio.  but i'm wondering if a different object format might not be more sensible.
*any* advice appreciated.  even a snippet would help.
i don't want to spend another week modelling a hand prop that turns out to be the size of the chrysler building when i open it in studio.  :)
thanks!
j
Post edited by jardine on
  • Richard HaseltineRichard Haseltine Posts: 112,009
    There is a preset for modo in the OBJ Import/Export options dialogue, and in the Morph Loaders, which should give the correct values.
  • 3anson3anson Posts: 314
    edited March 2019
    kk, export from DS at Modo scale, import at same scale. also export a dev figure at Modo scale and load that into your modeller as a reference for prop size.
    it pays to keep to a single scale at all times.
    for material surfaces, highlight the polys required and simply assign a texture, when naming a surface, do not have any spaces in the name, 'cos Modo will add sort of random digits where you have spaces.
    if you need to add a 'group' for boning/rigging purposes, that is in the Geometry dropdown as 'Set Group' afair. again highlight polys required and do not have spaces in the name.
    Post edited by 3anson on
    They aren't random - modo (and apparently the OBJ standard) consider space a separator so it will replace them with thei chacters code (20 in hex, 32 decimal) as it will other non-allowed characters which are allowed for modo's internal use.
  • jardinejardine Posts: 1,227
    thank you *very* much, Richard and 3anson.
    my latest attempt at propping is a lot closer to being useable than the previous have been.
    j
  • stueve007stueve007 Posts: 0
    Thanks so much for the explainations
    Just a quick question,
    Is Daz accept the animination created from MODO, and edit afterwards in Daz
    Cheers
