Help! Floor will not render!
Hi,
recently I purchased a Dojo environment:
https://www.daz3d.com/kendo-dojo-and-outfit-for-genesis-3-female-s
But when I load this scene and try to render it, the floor will not render. I looked up all parameters, everything seems to be ok. But I can do what I want, change height or move it slightly - it will not appear in the final render, there is a big "hole" instead. All other props are rendered properly.
Anybody an idea what is wrong?
Greetings
Rael
Post edited by rikas_7ef84af310 on
  • FishtalesFishtales Posts: 6,231
    Make sure the floor isn't below the Environment Ground.
  • It's definately above the ground. I also lifted it up, but it will not render still....
    how thick is the floor.   In some prgrams it has to be thikcker than 1 px  I think it is.
  • rikas_7ef84af310rikas_7ef84af310 Posts: 9
    edited March 2019
    hm now its to see on the jpg... strange...
    I take it you are using the right presets for the render engine, Iray or 3Delight?
