Iray Interior lights doesn't load
Hello everyone!
I am having some big problems while trying to render a scene with preset lights. I bought the "Sun Hall" environment https://www.daz3d.com/sun-hall but I have no luck to activate the lights. It's very dakr when I render, and no matter what I do, the "Linear Point lights" and the torches fire lights don t seem to appear.
I would like to render the interior as it is on the store page.
What can I do? Thank you so much!
Post edited by amalliach_858df2e8 on
  • felisfelis Posts: 6,498
    That set is old, so it will only have 3deligth materials.
    Usually you will need to convert materials to Iray, which generally can be done applying Iray Uber shader. But I don't think that can handle emission materials. So that will need some manual conversion.
    Or you could use this procudt to convert it:
    https://www.daz3d.com/rssy-3delight-to-iray-converter
  • FishtalesFishtales Posts: 6,231
    Click on the lights and make sure that Photometric is turned on for rendering in Iray.
