Removing normals?
Burpee
Is there a way to remove normal when exporting out of Hexagon?
As an example: If I have a flower petal and it has no thickness, just a grid, when you render in Poser and other softwares the underside of the petal will be darker in texture.
Can't I tell Hexagon to remove normal? I think there is an option in the export box but it doesn't seem to work.
If it is not possible in Hexagon, is there a way to do it in DS or Poser?
I take it into UV mapper (the free version) and reexport without the export normals checked.
Most excellent solution. Thank you so much!!
