Show aspect ratio shortcut
Hello,
Is there a way to create a shortcut for this? I can't seem to find it under "Workspace Settings"
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,718
    It's probably there but I can't see it. In the meantime, you can right-click on the Custom heading in Window>Workspace>Customise, select Create new Custom Action, check the Daz Script box, and paste this in
    var viewMgr = MainWindow.getViewportMgr();var activeView = viewMgr.getActiveViewport();if ( activeView ) {	var viewport3d = activeView.get3DViewport();	if ( viewport3d ) {		viewport3d.aspectOn = ! viewport3d.aspectOn;	}}
    giving it a label like Toggle Aspect Frame. Then you can assign a keyboard shortcut to that as usual.
  • Thank you. I will try!
  • MortzeMortze Posts: 186
    Thank you. It worked with me and is very useful!
