Bryce Content Bundle Install
TimVukmanTimVukman Posts: 45
Hi:
I would appreciate help with the message below. I can't find what it is referring to in order to fix it. I'm using Daz 3D Install Manager 1.0.1.90 and I get the message when I tick Bryce 7 Content Bundle 1 which I bought. I think I bought bundle 2 as well, but let's deal with this first.
The message
Install Manager cannot find a required path. The installer for "Bryce 7 Content Bundle 1" requires that the installed path for "Bryce 7 Pro;7" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Thanks,
Tim
  • fixmypcmikefixmypcmike Posts: 19,718
    Go to Settings (the gear icon in the upper right) > Applications and add the path Bryce is installed to.
  • TimVukmanTimVukman Posts: 45
    Thanks fixmypcmike.
    There was no entry for Bryce in the list, but I figured out the + sign was to add a directory path.
    Your quick response is really appreciated!
    Tim
    I really reccommend that you study this http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf It's free, put together by one of our Bryce Gurus
    Bryce content can be a bit pernickety as to where it is installed, and if the paths are not completely right you will miss a lot of it.
    Thanks chohole. I will read it for sure!
    Tim
