Need help fixing Smart Content
ZelrothZelroth Posts: 910
Hi
Me again. My smart content has decided to quit working. It is showing the content in the various categories, but each icon is indicating that the item is not to be found. I have tried resetting database and re-importing the meta-data, then cold booting my computer, bu nothing is working;. The files are still there. I can find them through the Content Library, but how do I fix the Smart Content?
  • frank0314frank0314 Posts: 15,114
    Check and see if CMS is running
  • ZelrothZelroth Posts: 910
    Yep It is running
  • fixmypcmikefixmypcmike Posts: 19,729
    If it's displaying the items it's not a CMS problem. Can you select an item that doesn't work, right-click and choose "Browse to file location", and post the full path?
    It says that the file does not exit when I left click. When I right click and choose show in content library - it does nothing. There is a triangle with an exclamation for each item. I know the files are there because I went to the product in the content library and verified, then left directory before trying to locate by right clicking.
    What is the path to where the files really are, and what do you have listed in Edit > Preferences > Content Library > Content Directory Manager for DS-formats and Poser-formats?
    The path is what first checked and it matches.
    What is the path?
    Sorry, couldn't access Studio earlier to copy accurately.
    DAZ Studio Formats
    - C:/DAZ 3D/Studio 4
    - C:/DAZ 3D/Studio 3/Content
    - C:/Users/Kat/Documents/DAZ 3D/Studio/My Library
    Poser Formats
    - C:/DAZ 3D/Studio 3/Gen 3 Content
    - C:/Program Files (x86)/DAZ/Studio/content
    - C:/DAZ 3D/Studio 3/Holiday/DAZ Free Content
    Other Import Formats
    - C:/DAZ 3D/Studio 3/content/Shader Mixer Scenes/Scenes
  • JaderailJaderail Posts: 0
    edited October 2013
    DAZ Studio Formats
    Poser Formats
    You should Only Have these listed.
    DAZ Studio Formats
    Poser Formats
    Then All content should show Properly.
    Post edited by Jaderail on
    The trouble is that if I remove the Studio 4 directory - I lose EVERYTHING that I installed with DIM.
    I'm about ready to give up on this computer's smart content - I made the changes (except I did leave Studio 4 directory alone) and now I have nothing showing up under Smart Content. I have closed Studio and cold booted the computer - nothing. reset and re-imported smart content - nothing. Closed and rebooted - still nothing. The Smart Content was working earlier this week. Even The Surface Tab isn't coming up with any items any more.
    Any suggestions before I uninstall and reinstall Studio?
    edited October 2013
    Why in the world did you install content to there? Just add that one to the list above then. The DIM auto Defaults to the MY DAZ 3D Library. I always just used it and then added my other folders like my DS3A Content folder.
    Please READ this thread http://www.daz3d.com/forums/discussion/31178/
    I've had files installed there since DIM was available. It is my way of being able to access the products that I have not downloaded yet but still want to use. My laptop has the same directory setup and is still working.
    Studio 4 WAS still in the directory listing when no smart content appeared.
    Thank you - I will check out that other thread.
    A failed or Crashed CMS Database is one thing that will cause Smart Content to fail until a new Database is created. I hope that is your issue. The Old Database must be removed or nothing seems to work until it is removed and a clean one created.
    Trying to recreate the Database didn't work, butn unistalling Studio and then recreating finally did.
    Thank you for all your help and patience. (Yay! I can work without fighting again)
