PWGhost
DkgooseDkgoose Posts: 1,451
Was PWGhost added to the Value category or is it just on sale for the halloween sale? I don't remember it ever being a Daz Original.
  • Richard HaseltineRichard Haseltine Posts: 112,275
    DAZ bought-out most (not pwSketch) of the Pose Works shaders and updated them for DS 4 a while back.
  • DkgooseDkgoose Posts: 1,451
    Oh nice
  • WillowRavenWillowRaven Posts: 3,787
    I am trying to use pwghost without much luck. Is there a trick to it other than any other shader?
  • JaderailJaderail Posts: 0
    They are Applied the same but all the Presets Auto load the shader no need to load it before you apply a preset.
    Then I'm doing something wrong or it needs re-installed, because it's showing up a solid bright mass of color, even in spot render.
    I do think we have had one update to the Bundle before I ever used the pwShaders, its possible you need to install new.
    ok. reinstalled, so now it's working. But ... can I lessen the transparency or change the color of the glow?
    I bought it and tried it out, some of them don't seem to work, and the tutorial is no where to be found, I did find out if you press ctrl and select the shader and choose ignore it keeps your features, except for designs on clothes, those disappear, although sometimes I have to delete the character and all and start over as the ghost effect does nothing
    Ohhh .... so if I hold control I can keep the textures with the glow?
    Sorta, it seems to give a better effect, some makeups are removed and like Tanked, the images on the shirt will be gone after applying the ghost setting
    The Tutorials are in Docs in your content folder, all the pwEffect shaders will add there.
    The control button technique is really helpful, and I figured out the color changes, too. I still can't figure out how to lessen the transparency, but hopefully it's in the reading. Thanks :D
    The PWGhost resources folder just has presets, no tutorial, and I didn't see a Docs folder :/
  • RodrakRodrak Posts: 81
    You are right. pwCatch, pwEffect etc. install manuals in \Docs\Poseworks but not pwGhost. Checked the .zip too, nothing.
