Do Geoshells have cutout opacity?
I'm trying to put white stars on a texture, I made a thread here https://www.daz3d.com/forums/discussion/comment/4333631
I'd like to add the stars as a layer on a GeoShell, but I can't find the cutout opacity function the set the image map of the stars. Not sure where I'm going wrong. Thank you!
  • HylasHylas Posts: 5,316
    edited February 2019
    Did you apply IRAY uber shader to the geoshell? If not, then the function is simply called Opacity instead of Cutout Opacity (but works pretty much the same way, I think.)
    Post edited by Hylas on
    Thank you SO MUCH, that works! Before I did have opacity or opacity strength, but it wasn't working. Making it cutout opacity and setting the map works perfectly.
  • Syrus_DanteSyrus_Dante Posts: 983
    In the Surface pane the list of shader settings can be quiet cluttering. If I search for Opacity or Cutout Opacity I use the text filter box on top of the surface pane. Just make shure your mouse cursor stays in the text box while you type in "op" this will show you the Opacity or Cutout Opacity without scrolling.
    Here's another thread about GeoShells and Cutout Opacity: Geoshell and material zones
    Post edited by Syrus_Dante on
