Problem with movement axis'
I have a model that for whatever reason the creator made the movement axis completely off
allignment of the object.
It makes setting the object in the scene a nightmare
Is there a way to perminately adjust the movement axis on a model so that it will match it's symmetry?
thanks
  • Mike BMike B Posts: 8
    Kinda sort of. You can rig it in Daz. Add a base bone and save it. How you may ask. Well, research prop rigging in Daz 3D.
    As to moving the pivot point for real, I would export it to Maya and move it where I wanted to save it and import back.
    or Hexagone good luck with that.  Good Luck
  • MattymanxMattymanx Posts: 7,002
    Using the Joint editor tool you could change the center point of the object and then resave it to the Daz Studio library
  • hmm will give it a shot
