Genesis rendering issue in Poser
pcw5150pcw5150 Posts: 7
edited December 1969 in Poser Discussion
Hi all,
It appears that Genesis V5 won't render at all when using the "Render to Queue" option. All other objects in the scene render fine (even if imported via DSON), but Genesis character is invisible. Genesis renders fine if not using the Render in Queue option.
Anyone else seen this? Any workarounds to make Genesis render properly when using the Render in Queue option?
Thanks,
Paul
  • pcw5150pcw5150 Posts: 7
    BTW...forgot to mention it happens in both PP 2012 and 2014.:coolgrin:
  • estheresther Posts: 641
    Yes, I have that problem too.
    I found another thread via search about this - appears Genesis and Poser Queue render don't work together. Below is the link to the thread:
    http://www.daz3d.com/forums/discussion/15500/
    Pity that. That means DAZ probably lost sales for Genesis 2 and content given this unfortunate issue. It may seem a "minor" issue to some; but, Render Queue is an important part of my workflow.
  • WandWWandW Posts: 2,910
    You could fry exporting a cr2 version of Genesis from Studio and see if that works...
  • wimvdb_dc63ee9ce6wimvdb_dc63ee9ce6 Posts: 183
    DSON changes the way a (genesis) figure is loaded in Poser. This behavior is not part of the queue manager, so the changes for the genesis figure will not be loaded.
    You can see the same if you disable DSON (move it away from the addon folder and restart poser) and load that scene.
