tails
Searching for brings no results but hair, mermaids and at least EasyTail for Genesis.
But I need a tail for a K4 costume. Does anybody know other tails as single props or obj?'
'Sin - character and outfit for V4" includes a tail prop. Do you think that it's possible to import and apply it to K4?
Post edited by Wolpi on
You should be able to. Just scale it to size, place it relatively close to where a tail would be, then parent it to K4. You can probably use the tail from M4/V4 creature creator morphs also as they're just parented props. You may need to adjust the tail's positioning as you pose and move K4 about.
Thank you very much, Vaskania! Yes, it works this way. But I chose the tail of the SilverKey Monkey and it looks perfect with the costume!
