Geometry Shells...
In this scene, I have a door that I want to export, so I can use it elsewhere, but it is attached to 3 other doors in the scene, inside a geometry shell. Is there any way I can export just one door from the shell?
Door I want
When selected with surface selector
  • SimonJMSimonJM Posts: 6,110
    Inside/with a geo shell?  Not saying you are wrong, but that does sound a little strange, I would have thought it might be an instance.
  • it could be a instance - i need the door either way
    Delete the instances and then export the door object?
  • Which set is it from? That may make it easier to figure out what you are seeing, and what you need to do.
