Morph Loader Pro Moving OBJs Instead of Morphing
Arah3D
I've used MLP before and found it really handy and easy to use, but this last time instead of applying the morph to the object I had, the morph shifted the whole obj either up or down. No matter what type of morph I tried, it only went up and down. I'm not sure what I'm suddenly doing wrong but I was hoping someone could provide a little insight into the problem?
Thank you!
That usually means that the preset in Morph Loader Pro, setting scale etc., doesn't match the one used exporting the OBJ
Altering the size of the morphs to fit the object fixed the issue, thank you so much!
