Render Challenge
For the January 2019 render challenge: Z-Day
I added an image but it is just a small attachment. How do I make it larger like other peoples images?
First click on the thumbnail attached to your post. In the new window that opens with the full-sized image, select and copy the URL from your browser's address bar. That is the location of your original image on the DAZ servers. Now, go back to your original post and move your mouse to the upper right corner of your post and click on the little gear icon. A popup will appear with only one option - Edit. Click on that and that will open an edit window with your original post. Scroll down to the bottom and use Return to place your cursor below the text. Now, go to the menu above the edit window and click on the image icon (little mountain and sun in a rectangle). In the resultant dialogue, paste the url that you copied earlier into the URL box. That will cause the dimensions of the actual image to appear in the width and height boxes below. Change the width parameter in that checkbox to 800 or less, if it isn't already. (that is the maximum that the forum software allows for embedded images). Press OK, and your image should appear in your post. To save your edits. click on Post Comment, and you're done.
It sounds a little complicated, but you'll get the hang of it pretty quickly.
Great ! Thank You !!
