"Error during rendering"
So, I got this message : "error during rendering" while rendering an image in 3Dlight. Closing this error window and trying to start another render results in a new error message, saying something like "Unable to render. Renderer already in use." I need to close and restart Daz3D to be able to render again.
I tried to render the same image in Iray : it works. Another image in 3Dlight : it works too. So, the problem is specifically this image when rendered in 3Dlight.
What could cause this problem?
There are rather a lot of possibilities. What happens if you load the scene and delete half the stuff? If that renders, try reloading the scene and deleting the other half. Keep doing that until you haev a single item that causes the render to fail. If both halves fail try deelting everythign and just rendering an empty scene - what happens?
Do I need to delete the stuff, or can I just hide it?
Hide shoudl work for testing, unless it's that DS as a whole is eating too much memory for the renderer to run.
