Reverse source shape from target (Transfer Utility) with script?
I'm currently learning simple scripting and working with the Transfer Utility: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/transferutility_dz
I wrote a script that works almost as intended, but I want to transfer morphs from the Genesis 2 Female in a non-default pose. I could use the "Reverse source shape from target" option, however I just can't find the corresponding setter method in the API documentation. There are setter methods for almost everything else, so I found this a bit strange. Is it missing or am I just overlooking it? Maybe there is another way to achive the same effect?
  • rbtwhizrbtwhiz Posts: 2,470
    The following methods provide access to the option labled "Reverse Source Shape From Target" in the Transfer Utility dialog:
    • DzTransferUtility::getAdjustTargetBase()
    • DzTransferUtility::setAdjustTargetBase()
    -Rob
  • Thanks for the quick reply! It didn't quite work at first, but I finally got it working now, though I'm not sure how exactly. I'm curious to know if the code/API has been changed somehow? I used SourceMorphTransferType.Favorites for the enumeration at first, but suddenly got an error and had to change it to DzTransferUtility.Favorites
    edited December 2018
    Values of enumerated data-types (i.e., an enum) are accessed like (static const) properties of the object (or an instance of the object), using either dot (e.g., DzTransferUtility.NameList, DzTransferUtility.Favorites, etc.) or bracket (e.g., DzTransferUtility[ "NameList" ], DzTransferUtility[ "Favorites" ], etc.) notation. Values of enumerated data-types are not accessed like properties on an object named after the data-type (e.g. SourceMorphTransferType.NameList, SourceMorphTransferType[ "Favorites" ], etc.), unless you have created an instance of the object named after the data-type (not recommended).
    -Rob
    Post edited by rbtwhiz on
