Goz
GOZ DOES NOT WORK IN DAZ STUDIO 11 BETA
plugin does not load
  • Did the versions match? Is it not listed at all in Help>About Installed plug-ins, or is it listed but shown as non-functioning for some reason? Remember that you may have only one GoZ for Daz Studio isntalled at once - if you install for the release version of DS the beta version will be uninstalled if present, and vice versa.
  • Filename :
    C:/Program Files/DAZ 3D/DAZ 3D/DAZStudio4 Public Build/plugins/dzgoz.dll
    Name :
    dzgoz
    Author :
    Unknown
    Version :
    0.0.0.0
    Reason :
    Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
    Thank you for your attention
  • So did you download and install the beta version of GoZ at the saem time as the beta version of DS?
  • yes, and then reinstalled the latest version
    available and still does not work.
    However in the previous version of DazStudio it works without problem.
  • The latest version of both application and plug-in?
  • jardinejardine Posts: 1,217
    try uninstalling the GoZ plugin via DIM, setting up the correct path to your current zbrush installation in DIM application preferences, and reinstalling the plugin.
    worked for me.
    j
  • It does not work
    worked for me.
    j
    It does not work
