Preventing character bones affecting wardrobe bones
So, here's a little situation - I have a few custom clothing made for myself, a pair of shoes in this case.
I quickly rigged using Transfer Utility first, then moved on and finished rigging, weight mapping, and etc.
Problem is that - I want this shoe to move on its own, except for the character's shin.
But character's foot and toes are still affecting the shoes' movement.
I have changed the name of bones and nodes but no luck.
Is there something I'm not aware of??
Thanks!
  • barbultbarbult Posts: 27,502
    Did you try resaving the shoes as figure/prop asset after renaming things and then closing DS and restarting DS and seeing if it works?
  • Are you sure you renamed the bones, not just relabelled them? The thing that shows in the Scene pane is just the label, not the name.
  • Have you tried not fitting the shoes to the character, but just parenting them to the shins instead (you'd need separate objects for  each foot).
