LDPR is not combining layers
sinfanysinfany Posts: 190
edited September 2013 in The Commons
Hi,
Everything seemed to be working fine until recently. Inexplicably, I started getting error messages when trying to combine layers (see attachment). I've tried moving layers manually but it doesn't look right.
Also, the background doesn't show in the final render - it's just black and I have to delete it in PS and insert one of my own backdrops, which is okay but I shouldn't have to do this.
Has anyone had this happen? I contacted tech support at Dreamlight but it could be days before I get a reply.
I'm on a Mac and use PS6.
Thanks!
428 x 159 - 24K
361 x 365 - 35K
Post edited by sinfany on
  • VanguardVanguard Posts: 505
    Sounds like you are running into the same problem described and remedied here
    http://www.daz3d.com/forums/discussion/26593/P390/#433615
  • sinfanysinfany Posts: 190
    It does look similar, except that I do select all 7 rendered layers. I get the - command "Make" is not currently available - it continues until the "Layer 'sky bounce' is not available'".
    I use the LDP-R Combine command in the Actions menu. What's weird is that I've been using the same process as before without glitches and it doesn't seem to work anymore. Gremlins?
  • RiffulRifful Posts: 0
    There was an update to add the custom lights functionality (which is awesome), but the new action script has some glitches apparently. What I found worked the best is opening them in order from 0(fog), and 1-7, then with 7 on top run the combine action, then add the layers for custom lights by hand. that worked for me.
    I'm using CS5 btw.
    Post edited by Rifful on
