Linked Morphs
Hey,
is it possible to link morphs in a way that do have exactly the opposite percentual value?
E.g. I have Morph A and Morph B
I set Morph A to 50%, Morph B is now automatically set to 50%
I slide Morph A to 30%, Morph B is 70%
I set Morph A to 0% Morph B is 100%
I there a way to do this?
thanks
  • Use ERC Delta Add with a scalar of -1, and set the default value of the controlled morph to 100% - just be aware that a) that will then load at 100% everytime the item loads, so not something you want to do to one of the base figures (especially not if you plan to share or sell the results, though you could add an ERC Multiply link to an on/off controller) and b) users will be able to edit the local value to change the behaviour.
  • Hurdy3DHurdy3D Posts: 1,113
    edited December 2018
    This was helpfull, I found a very good solutions which also works on base figures.
    I create additional to Morph A and Morph B a new property called Morph Toggle.
    Instead of ERC Delta Add I use ERC [Keyed] with a Linear Type (see Screenshot).
    I set the default value of the Toggle to -1% and the min value to -1%, too.
    As long the Toggle Morph is -1% it is disabled. Starting on 0% Morph A is 100% and  0% on 50% both are 50%.
    775 x 639 - 28K
    Post edited by Hurdy3D on
