G1 UVs to G8
evacyn
Is there any way to convert Genesis 1 UVs to use on a Genesis 8 character? I have the Legacy UVs products, but they only have an option to get Aiko 5 to Genesis 3. The only Genesis 8 option is Victoria 5.
Thanks!
Evacyn, you can use the Map Transfer utility in DAZ Studio to convert an Aiko 5 or any other Genesis UV texture to Victoria 5. Then you can put the texture onto Genesis 8 using "Legacy UVs for Genesis 8: Victoria 5".
For tutorials on the Map Transfer utility see either:
https://www.daz3d.com/forums/discussion/184696/tutorial-from-map-transfer-to-material-presets
https://www.daz3d.com/forums/discussion/95701/tutorial-converting-custom-genesis-2-uvs-to-genesis-3
Awesome - thank you so much for the response :) I'll give it a go!
