CMS issues..., again.
I have just installed the last Daz 4.11.0.236 Pro Edition (674 b) Public Build BETA update and then started to hace CMS issues again. Content Library is fine, but Smart Content doesn't show. Any clue, please?
Do you get the pop-up about requiring a PostgreSQL connection when you launch DS? If you checxk Task Manager, with Details on, or the mac equivalent do you see several PostgreSQL processes running after DS starts? What security software are you running?
Hi, Richard. Yes, I get the pop-up when launching DS. Following your suggestions, I checked for PostgreSQL processes at the Task manager and cannot see any of them. All I see is the DS process.
Are you sure you have one version (32 or 64 bit, beta or release) of PostgreSQL installed? If so, what security software are you running?
Hi, Richard. Yes, I installed PostgreSGL beta version via DIM, not only once but several times, trying to figure out what is going on. I should have said before that it's the first time that I am experiencing this issue, and it started when I just downloaded the last Daz 4.11.0.236 Pro Edition (674 b) Public Build BETA update. I've been trying by creating exemptions on both windows 7 firewall and antivirus_ by the way, it's AVAST._ with any sign of improvement. Thanks for your attentiveness in this regard,.
You could try disconnecting from the net, disabling Avast, and seeing if DS will then work with PostgreSQL. Do note, however, that the 32 bit and 64 bit versions can't read each other's databases so if you uninstalling and reinstalling ended switching that might also be a factor.
