Is it possible to join multiple terrains into a single unit for editing?
I want to create a larger terrain than the stock version so I can edit it and manipulate it without losing resolution or adding distortion. Editing the single terrain is no problem, but to get the size I want necessitates resizing along all its axes which results in some rather funky-looking end results. I'd like to put together perhaps a 6x6 terrain that I can edit as a single unit, if that's possible.
Is there a way to do this in Bryce, or do I need to bring in another program for exporting or importing the terrains?
  • HoroHoro Posts: 11,689
    You can tile terrains. Disable the random options and follow a path (e.g. East - South - West). Keep the default size, assemble the terrains in the GUI, then group them and resize as needed. No additional program is needed.
  • StuartBStuartB Posts: 600
    Here's a tutorial on how to tile them.
    Terrain Tiler.
  • S RayS Ray Posts: 407
    Here's a tutorial that explains the whole tilling procedure. Tiling Terrains in Bryce
  • I knew it had to be something obvious.
    Just wasn't expecting it to be that obvious.
    Thanks, all!
