Carrara 8.5 and Shaper plugin by inagoni
araneldonaraneldon Posts: 712
There is no evaluation version of this plugin, so I gotta ask:
Does it work with TriAx/Genesis content? How about Poser content (V4, M4, etc)?
  • FenricFenric Posts: 351
    It seems to work fine in 8.5, including genesis and genesis conforming clothing. It has always worked on V4/M4, and I use it frequently to quickly fix pokethroughs and minor shaping issues.
  • araneldonaraneldon Posts: 712
    Excellent, thank you :)
  • Mosk the ScribeMosk the Scribe Posts: 904
    How do you use Shaper to fix poke through? (I have several Inagoni plugins and hadn't quite gotten around to getting Shaper. But if it helps with Poke through, I think I'd grab it. Thanks.
    After you have posed the figure, you apply the Shaper modifier. This gives you a 3D grid of grab handles that act like magnets - you pull the handles and they drag the mesh with them.
    It's sort of pose postwork: it is only good for static poses and if you change the pose you'll have to re-do the fixes.
