DAZ Render Output Question
Fragg1960Fragg1960 Posts: 363
edited September 2013 in The Commons
Is it possible to get render output similar to the attached image in Studio?
I know about PWToon and Manga Shaders, and Visual Novel Shaders, etc., however, as much as I've fiddled with those, the output has not been close. I know Poser 2014 new comic preview looks pretty good (with Treshold controls for line width, etc.). Can Studio produce similar output with existing tools?
476 x 267 - 93K
Post edited by Fragg1960 on
  • none01ohonenone01ohone Posts: 862
    There's a Cartoon render setting but I've not tried it.
    526 x 979 - 152K
    Just tried Cartoon.
    Distant light 200%
    Render setting Gain 8.00.
    957 x 873 - 315K
    Fiddled a bit more.
    using:
    shadow samples 8
    gain 2
    Gamma correction ON
    Shading Rate 0.20
    Used another Spotlight to generate more highlights.
    I'm sure others here in the forum know of better settings. Just wait a while. Maybe if you use those other shaders in conjunction with the cartoon render option, you may be able to get closer.
    957 x 873 - 354K
  • Fragg1960Fragg1960 Posts: 363
    Thanks for helping out with the settings and renders. Since Poser can do this type of stuff natively, I was just curious if it was also possible to do in Studio without a plug-in (and get good results).
  • HastyDaveHastyDave Posts: 109
    I've been experimenting.
    I used BishounenTaurus's free Geometry Shell Outline shader (from this thread) and his Visual Style Shaders.
    718 x 403 - 151K
    Sounds like what you want is more of a hidden-line wireframe render. Try this thread as it's got some options: http://www.daz3d.com/forums/discussion/2693/
