Crashes
Everytime i attempt to render DAZ JUST KEEPS CRASHING, I'm getting fed up with spending a lot of money on this DAZ just to keep getting crashes when attemting to do a render. I have now totaly uninstalled it , don't know if i can be botherd to re install it for the third time. Might as well spend my money on another software rather than daz products that i can not render.
  • Maybe is your hardware fault? And maybe describe your hardware...
  • Also, were you rendering in Iray or 3Delight?
  • Thank you for your replys, Hardware not an issue, 32g ram, i17 processor, wind 10, good graphics card, not had any issues untill just lately, 3 times uninstall and re install and just keeps crashing when attempting to render, No idea why?
  • Rendering in Iray, sorry forgot to mention it.
  • felisfelis Posts: 6,658
    Does it crash if you just render a simple object like a primitive?
  • What is the good graphics card? Are you sure it is using nVidia drivers, assuming it's an nVidia card, not those provided by Windows Update (which can be an issue)? Do the crashes generate an error report, or do they go straight to desktop, or do they actually crash the machine (which would almost certainly be a driver or hardware issue)?
  • Yeh its a gtx nvidia card, it seems to crash just as its about to create its first iritations, it dos everything ok untill this point, I have been rendering with this pc for a couple of years now, i do regular updates and driver updates etc, its just seems to have happen within the past 2 weeks, i have uninstalled and re insttaled adfter cleaning the drive, cgheck for viruses and all that, it just seems to have given up when rendering, oh yeh, it will do a spopt render, but not a normal render.
  • Sometimes is not that good update graphic cards driver...did you tried to downgrade to a version of "older" driver?
  • I'll give that a try, Thanks.
  • OK so its seems I have work it out, but for the life of me do not understand why it was not rendering, turns out I re installed everything, I made the same scene with the same props as before, however it ssems not to render when I use The canvases, I have the beauty pass, the distance pass, the depth path, and enviro lighting path canvases.  Yet when i remove them and close down the sfotware, then re open it, it renders, No Idea why.
