Gen 2 Morphs
Akulla3DAkulla3D Posts: 131
So I installed Gen 2 using the new fangled installer, worked okay found Base Model fine installed some hair great found it. I installed the head and body morphs but I cant find them. Where do they get installed to and I am talking about the smart content tab in the program.
By the way, documentation is unsat.
  • kakmankakman Posts: 225
    They will not be listed as "content". They are in the "parameters" tab when you select "Actor" under the two "Genesis 2" lines.
  • FractalDimensiaFractalDimensia Posts: 0
    You can find a complete thread on this if you're interested. It is an ongoing discussion for some time.
    http://www.daz3d.com/forums/discussion/25968/
    FD
  • DartanbeckDartanbeck Posts: 22,159
    Yeah.
    Genesis is a new beast! No INJs to load. Once you istall the new morphs, they simply are there in every fresh load of Genesis (same for Genesis 2)
  • Akulla3DAkulla3D Posts: 131
    FD
    Thanks will check
    Yeah.
    ya so far I like it alot, and still some things like the mats that need work but that always happens with a new model. It took 6 months to get decent mats when V4 came out.
    Since I am thinking about it and I got you alls attention. How do you do a non-DAZ install, for example if I buy a product at Rendo. etc.
    akulla3D said:
    Yeah.
    Yeah, these are much better, don't you think? They need work, but...
    Since I am thinking about it and I got you alls attention. How do you do a non-DAZ install, for example if I buy a product at Rendo. etc.Whatever you do, don't install to somewhere that DIM installed to. Well, people do, but I don't consider it a good idea. I find it best to just make another directory along side if you don't already have a folder for Rendo stuff. Like if you use the DIM's "My DAZ 3D Library", you could maybe make a folder next to it called "My Rendo Libary".
    Are you familiar with the older runtime setups? That's how I do mine. I have one for Vehicles, one for Environments, Animals, etc.,
    Here's a couple of articles I wrote about:
    Making a custom Carrara browser and
    Making Custom Runtimes
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    It is still going into a Runtime or DS content structure. It is recommended that the only content in a content folder set installed by Install Manager be installed by Install Manager, and other content be installed to a different content folder set. You just add them like you add any other Carrara content folders on the content tab. If the content comes with Metadata for adding it to the Smart Content Tab then you have to import it into the Database in DS before it will show up on the Smart Content tab in carrara.
