Error message when loading LIE file
Help please!
I just went to use a LIE preset I had made but it wouldn't load and I got this:
Error reading file, see log for more details.
When I looked in the log this was what it said:
/Animals/HivewireHorse/Materials/LIE Presets/DWD_Pintos/Fetlocks1.duf (4,10): unexpected character
Any ideas folks? When I sent the files to be beta tested they came through fine and I have not changed any thing.
  • Richard HaseltineRichard Haseltine Posts: 111,374
    edited November 2018
    That sounds like file corruption - can you rescue the copy from the version you sent to your tester? If that is the issue, you may want to check your drive - it may be a sign of trouble to come.
  • That sounds like file corruption - can you rescue the copy from the version you sent to your tester? If that is the issue, you may want to check your drive - it may be a sign of trouble to come.
    Thanks Richard I'll try that and see what happens. I hope there is nothing wrong with the drive, I can't afford to fix it right now :(
