HP Tilir Texture
Does HP Tilir come with anatomical elements, specifically areola/nipple textures, or does it not have them? If it doesn't, how would I go about adding them to the model? I've tried a few renders but they come out looking like a barbie doll. I don't really care about the lower anatomical bits but not having breast textures is a bit weird.
  • fastbike1fastbike1 Posts: 4,081
    edited October 2018
    FWIW, areola and nipples are not considered "Anatomical elements" that term is left to genitals.
    Nevertheless, HP Tilr does not come with textures for areola and nipples . You can still achieve what you want, by using any Genesis 3 character texture, then changing the Base Color in Surfaces:Skin-Lips-Nails to whatever you want. You will also need to change the Translucency Color. I would recommend using the RGB values from whichever HP Tilr skin you desire.
    See attached quick render. There are definitely areola under the top.
    650 x 975 - 428K
    Post edited by fastbike1 on
  • defectedsaintdefectedsaint Posts: 76
    edited October 2018
    That would work but I want to use the extra textures and I can't use a base color for that. What I decided to do was just edit the jpeg directly and photoshop nipples onto it.
    Image removed - please see https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
    It's not perfect, especially since my photoshop skills are lacking, but the nipples are there and I get to use the skin as I want it.
    edited October 2018
    @defectedsaint
    Since you're willing to Photoshop, you might consider this: https://www.daz3d.com/build-a-babe-fantasy-skin-merchant-resource
