Having install problems
PamelaSConleyPamelaSConley Posts: 3
I'm very new here and can't seem to get things to install right. The Photoshop 3d Bridge for Daz Studio 4.5 install gives me this message: "Install Manager cannot find a required path. The installer for "Photoshop 3D Bridge for DAZ Studio 4.5+ (Win 32-bit)" requires that the installed path for "Photoshop CS6;CS5;CS4 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again."
I go to the settings and applications and tell it where Photoshop CS6 is located and it doesn't help.
Also, DIM seems to download and install to both 32 bit and 64 bit. This can't be right is it? Should I uninstall everything and do only certain ones, in a certain order.
Thanks,
  • fixmypcmikefixmypcmike Posts: 19,705
    If you click the "Download Filters" button in the upper left of the "Ready To Download" tab you can select what applications, OS, and bit-depth to use.
    Can you post a screenshot of the Settings > Applications tab?
  • peter_milesnzpeter_milesnz Posts: 1
    edited September 2013
    I have the same problem with just the photoshop plug-in too.
    'Install failed' ... "Install Manager cannot find a required path.... etc"
    I have photoshop CS6. Mac 10.6.8". Everything Daz installed without a hitch. Just not the photoshop plug-in.
    There is only one application listed for me under... 'install manager/Settings/applications'
    DAZ Studio 4.5+ (64-bit) /Applications/DAZ 3D/DAZStudio4 64-bit
    Note. On further tracking down I found the fix elsewhere on this forum.
    Thanks
    Peter
    Post edited by peter_milesnz on
  • rob-2360776rob-2360776 Posts: 1
    Thanks
    Peter
    Where? Because I'm having the same problem and I can not figure it out.
    Thanks.
    Thanks
    Peter
    Thanks.
    In DIM go to Settings (the gear icon) > Applications and add the path for Photoshop.
  • SiscaSisca Posts: 875
    Do you have the 32bit or 64bit version of Photoshop installed? If you have 64bit but not 32bit then the 32bit install will fail.
