Bridge
I keep getting this error message when I try to add to scene. Any idea what I am doing wrong?
1606 x 924 - 190K
  • Richard HaseltineRichard Haseltine Posts: 112,109
    edited October 2018
    That looks like missing asset files for a pre-DS 4 scene file. How did you install the set?
    Edit: I just installed and it has only Poser files so that looks like something you had saved yourself, which would have generated old-style native geometry files in the Data folder - it seems likely that is missing or in an unmapped content directory. You should, however, be able to load the actual Poser .pp2 prop files and use those in place of the missing items - materials that old would probably need tweaking, especially if you render in Iray.
  • I used Install manager to download and install it. I just tried to use the Poser files but just keep getting error messages.
  • What error mesages - are they any more explicit than thsoe for the .daz file?
  • This is what I get when trying Poser. (My first/original post error was Daz.
    1584 x 981 - 222K
  • That might happen if you had installed via Connect, then the files were removed (or the Connect directory removed from DS' list) - if there's a Connect install, according to the database, it will be used in preference to a DIM install. In the Content Library find the Products List>A, and right-click on the Asbru Crossing folder - does the menu give Install or Uninstall? If it has Uninstall click that and try again with the files from DIM.
  • When you say DIM are you talking about Daz Install Manager?
  • I am such an idiot. I forgot to purchase Asbru Crossing.
    Thanks for your help !!
