Limit section plane to specific objects?
Is there any way to restrict an iray section plane such that it only affects certain things? I'm trying to make someone disappear into a free standing magic portal but the plane removes everything behind it.
  • Not within the UI. I don't know if something could be done using Light Path Expressions in Canvasses, in the Advanced tab of Render Settings.
  • grinch2901grinch2901 Posts: 1,247
    You can do two renders, one with the figure/portal/section plane and a transparant background, and then another with the environment, overlay the two to get a composite image.  Often can work okay if you have the same lighting in both.
