Does anyone know how to remove things from the Scripts Tab?SOLVED
carrie58carrie58 Posts: 4,178
edited October 2018 in The Commons
This has been driving me nuts cause there are a few things I no longer use cluttering up the script tab and I would like to remove them ...but I can't figure out how ...help ......please ...
Post edited by carrie58 on
  • Window menu > workspace > customize
    On the right side go to menus tab, then expand main menu, then scripts. Right click what you want to remove and click remove item. Then hit apply and accept.
  • NorthOf45NorthOf45 Posts: 5,921
    Main Menu -> Window -> Workspace -> Customize, or just hit F3.
    On the right side panel, select the Menus tab. At the top of the list there should be an entry for Main Menu. Expand to show the submenu items, one of which should be "&Scripts". Expand that one and right-click on the offending entries and select "Remove Item". You can also add a submenu if you want to group the ones you keep into a more organized fashion.
  • carrie58carrie58 Posts: 4,178
    Thank you so very much!!! @DestinysGarden and @Northof45 ,that has been driving me nuts,(which is a very short trip IMPO) the list was getting longer and I couldn't get rid of the ones I no lnger use .Thank you thank you
  • MaRuMaRu Posts: 3
    Glad I found this thread!!
