Super natural brows instructions/tutorial?
I've been attempting to use the Super Natural Brows product for the last half hour. I don't see any change in my model (G8 female). I can't find a readme, tutorial, instruction doc. I'm not trying to create a model to sell. I'd just like to have different brows on a character I'm trying to render. Can someone point me to a tutorial, either video or pdf, or provide steps to apply the product to a model from the point of the model being loaded in the scene and brows removed? I've seen instructions about selecting the brows. Where do I do that? In the Parameters/Actors tab? In the Surfaces tab? In the Shaping tab? In the Scene tab? If it's the Parameters tab, do I select all six properties for inner, middle, outer? What about center? I'm sure I'm making this a lot more difficult than it should be, but some clear, detail steps would be greatly appreciated. Thanks in advance for any help!
  • nemesis10nemesis10 Posts: 4,009
    !) load your model
    2) attach the brow like you would a garment (I generally drag the brow from smart content onto the figure to make it conform).
    3) go into the scene to select the brow and either apply the appropriate presets or go into the brow's parameters to make manual adjustments
    4) if you want to remove previous painted brows and your figure doesn't have a browless texture, I recommend the Brow remover product.... if there is an actor that is a brow, delete it and apply the Super Natural Brow.
  • Oh good grief! I completely missed seeing that the top node had the attachment. It's terrifically easy to use now that I'm starting in the right place. Thank you so much!
