cannot find Brickyard
edited September 2018 in New Users
[cannot find Brickyard]
Hello!
What is the problem?
Win 10 (64bit)
Daz Studio 4.10.0.123 pro.(64 bit)
Genesis 3 male 3delight
new setup
Thank you!
1680 x 1050 - 487K
  • Richard HaseltineRichard Haseltine Posts: 112,348
    Hmm, usually that means that a Shader Mixer shader has not compiled properly - the fix can soemtimes be as simpel as redoing the render, but if that fails you need to go to your DS temp folder (set in Edit>Preferences) and delete the Render folder, then restart the render. (Reloading the scene or restarting DS will also usually work.)
  • bamboojibambooji Posts: 45
    edited September 2019
    c:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\shaders\brickyard\   I erased the files in brickyard and it worked OK.  You can do what Richard said (Edit>Preferences) then open shaders and delete the files there.
    Post edited by bambooji on
