Another Install Manager Question
DarQueBirdDarQueBird Posts: 14
Hi, I am having trouble installing Raven Court with install manager for Poser 7. It says it has been installed but when I go and check its not there. I have read the readme's and watched the tutorials but it still won't work for me... Is it that Raven Court wont work with Poser 7?
Thank you much for any help. :-)
    It works for me, in P8. However mine was a manual install. Where are you looking for it. This comes as a character, not a prop afaicr.
  • Richard HaseltineRichard Haseltine Posts: 112,268
    Are you sure you have DIM pointed to your Poser content library, or Poser pointed to use the folder you install to as a library?
  • LocusSolusLocusSolus Posts: 59
    Again, I insist on the fact that Dim should display (at least on the INSTALLED tab) the recipient directory for MUCH MORE EASIER use. There are lot of room for that in the browser rows. Sorting the browser by this criteria must be just under the hand of a beginner developper coding as well.
    Please !
    And yes, Laurie's Raven Court is a nice Edgar Poe's "Leonore" poem environment.
  • frank0314frank0314 Posts: 15,120
    You should put in a feature request through customer service Technical support. Make sure it's labeled Feature Request for DIM
  • LindseyLindsey Posts: 2,020
    Please !
    On the Ready to Install tab, click on the Show Details button for the recipient directory. You can even change it if you have multiple recipient directories defined.
    642 x 720 - 110K
    Go to the Installed tab, select an item, right click on it for the context menu, and there are several options. One of them is Installed Files which will list every file that has been installed for this product, and where it was installed to.
